Fixes in January 2020? r720 AP Unleashed Upload Speed Double Download Speed, Up & Down Speeds Half or Less when WPA2 or Hidden SSID Used
taylor_wall
Access point is powered by a wall adaptor. Gigabit connection is coming in at 850m/850m as tested by a Thinkpad immediately before plugging the tested Cat6 into the r720.
Using the Unleashed firmware 200.6 or 200.7:
-250m/500m in speedflex using no password, visible SSID
-50m/100m in speedflex using no password, hidden SSID
-160m/480m in speedflex using WPA2, visible SSID
The best case scenario is not secure at all, and still has the issue of download speeds being severely limited. I should have a PoE injector from Ruckus soon to test and see if that makes a difference. Right now no QoS is enabled, 80mhz channel width on 5ghz with no overlap with other networks, the microwave is not running, and I'm in the same room as the router with clear line of sight.
The second ethernet port is used to connect other devices, but when I remove it the speeds are the same.
I've disabled 802.11g clients and made sure nobody else is on the network and the results seem to be the same.
On iPhones in particular (iPhone X and iPhone 11), the speeds are even worse than what I'm getting on a OnePlus 3T from 2017.
I'm going to try the oldest standalone software I can find when I can to see if it has issues. If anyone else has these same issues feel free to comment or post your workaround here.
13 REPLIES 13
Esteemed Contributor II
106 what Taylor, that's not an Unleashed firmware version...?
Hi Taylor, our developers changed WPA2 encryption algorithm in response to a Security Bulletin, that went into Solo AP, ZD, SZ, and Unleashed around Christmas. They are now "adjusting" the changes in each new release.
hayward_kong
Contributor III
Taylor,  as for your lag spikes....change the freq of background scanning ...
someone suggested it and worked for them
 https://forums.ruckuswireless.com/ruckuswireless/topics/lag-spikes-when-gaming-every-30-seconds-or-...
ljplewis
Has there been a solution yet?
No matter what I do, I cannot get a better air speed than 351Mbps download and 866Mbps upload.
160Mhz channel width gives worse performance as well.
Seems like the firmware has made this a dead device?
