12-03-2015 07:58 AM
12-03-2015 08:06 AM
Are you using a controller for the APs? If so, there is a way to set what is called an HESSID which would be the same MAC on all the APs for the BSSID (which is the SSID's MAC).
First let me know if you are using a controller before we dive into this.
12-03-2015 08:07 AM
12-03-2015 08:12 AM
In that case, using an HESSID, if the code is up to date should help you as it would make the BSSID the same MAC for all APs broadcasting that SSID in your network. The HESSID needs to be the MAC of one of the BSSIDs in your existing network. So, it has to be a real MAC from your equipment.
Try that and let us know if you have issues afterwards.
12-03-2015 08:18 AM
