Showing results forย
Search instead forย
Did you mean:ย
FW upgrade issue
I have 30 H510 APs having unknown FW version and not registering in SmartZone. I have the correct FW downloaded but APs are not allowing access through web portal, TFTP or SSH. Please help me on FW upgrade.
12 REPLIES 12
arun_nagaraj
Hi Chamika,
Have you tried resetting one of the AP and check if they are accessible over SSH.
Arun N
Reset many times. Hard reset as well.
Is it possible to upgrade the FW with USB as these all APs are having USB port.
Hi Chamika,
No, USB port is not for firmware upgrade. USB port is given for IOT dongle support.
Syamantak Omer
Syamantak Omer
RUCKUS Networks, CommScope!
Follow me on LinkedIn
Hi Chamika! It seems strange that hard reset didn't help. I would completely separate an AP from any network and connect to a laptop via an isolated switch or a PoE injector. Then do the hard reset and try to web-access the AP at 192.168.0.1.
Does the AP broadcast any SSIDs after hard reset?
