EAP-TSL
can we do EAP-TSL authentication method with Rukus wireless solution.
4 REPLIES 4
albert_pierson
Contributor III
Hi Sameer,
The EAP method is negotiated between the  client and the RADIUS authentication server.  Ruckus is transparent and can pass most methods.
802.1x EAP-TLS which uses client side certificates is the most secure EAP method and is definitely supported.
I hope this answers your question.
Hello Albert,
thanks for reply..
I am coming from Cisco And Aruba WLAN security. so Rukus is new for me. its very help full if i get the installation and configuration documents for same.
Thanks in Advance
albert_pierson
Contributor III
HI Sameer,
Configuring a WLAN(SSID) profile to do 802.1x authentication is covered in the user/admin guides for each product.
For latest ZD version:
https://support.ruckuswireless.com/documents/2150-zonedirector-10-1-0-ga-user-guide
802.1x configuration starts on page 100
For vSZ-H /SZ300 latest version:
https://support.ruckuswireless.com/documents/2327-smartzone-5-0-ga-administrator-guide-sz300-vsz-h
WLAN configuration starts on pg.161, creating 802.1x admin roles on pg. 191
For vSZ-E/ SZ-100 latest version:
https://support.ruckuswireless.com/documents/2302-smartzone-5-0-ga-administrator-guide-sz100-vsz-e
WLAN configuration starts on pg 147.
You may also want to check our Knowledge base (I searched for 802.1x and TLS)
https://support.ruckuswireless.com/articles/000002428
https://support.ruckuswireless.com/articles/000001138
https://support.ruckuswireless.com/articles/000001152
I hope you find this information helpful
Thanks for choosing Ruckus Networks, an Arris company!
Thanks Albert.
