Does Ruckus Unleashed now support up to 50 APs????
emmanuel_oladel
4 REPLIES 4
phil_coverdale_
Hi Emmanuel,
Yes, but only if you're running software version 200.7+ and using only 802.11ac Wave 2 APs.
If there are earlier APs in the Unleashed network, then you will still be limited to 25 as there is a possibility of an earlier AP becoming the master in the event of an AP reboot.
Phil.
elisio_melo
Hi. For an Unleashed network with 50 APs, do we need to buy two units of SKU 806-RUNL-1U00 (End User Base Support for Unleashed Access Points (up to 25), 1 Year)? Or one unit of SKU 806-RUNL-1U00 plus 25 units of 806-0001-1U00  (End User Per-AP Support for each Unleashed AP from 26-50)? Regards, Elisio.
You don’t need to buy the support. Unleashed is free to use as long as you don’t need to get help from ruckus directly.
sanjay_kumar
RUCKUS Team Member
Hi Elsio,
I believe you might need to check with your local SE to give you best answer.
