Does R750 support LACP?
yee_nok_li
Dear support,
please help check if ZD1205 +R750 support below or not, thanks.
1. Does R750 support Link Aggregation?
2. Does R750 support LACP
Nok
10 REPLIES 10
DarrelRhodes
Valued Contributor
Hi Yee,
The R750 does not currently support link aggregation.
I believe the view is that as the R750 has a multi-gig 2.5Gbps Ethernet interface; port link aggregation with the second 1Gbps port is unneccessary. It is highly unlikely, outside of a lab test environment, that TCP data throughput will exceed 2.5Gbps on the Ethernet port.
Thanks,
Darrel.
yee_nok_li
Thanks a lot. Darrel
koji_onodera
Could you please give us which model that can support LACP?
Especially the newer AP model such as R850, R650, R550.
Thank you
Kouji
richard_chaffey
Hello Darrel, in the last 11 months since your update, you don’t happen to know if the R750 had its link aggregation enabled?
I have a great system upgrade opportunity becoming available, but the client wants to keep their switch for the time being..  And maybe one day in the future have 3.5Gig over both connections
