Do you use an electrical box for APs mounted on sheet rock ceilings?
newsfool
This will sound silly, but I'm curious what everyone else does.
I have several R610's I need to mount on sheet rock ceilings in new construction. I am going to use the multipurpose mounting bracket 902-0120-0000 to mount the APs to the ceiling.
The electrician will run cat6 to the ceiling location, but I assume I don't want him to terminate in a gang box? It seems simpler if the cable just "pokes" through the sheet rock.
I am curious what others do and if there's a standardized procedure for how to handle the cable mounting to a sheet rock ceiling.
Thanks.
6 REPLIES 6
6A is difficult to work with. Based on the above, I would terminate it in the ceiling with a cat6a jack behind a mud ring and then use a small-diameter 6a patch cable to attach to the AP (https://www.belden.com/products/enterprise/copper/patch-cords/cat-6a/small-diameter).
so in this scenario do you even put a faceplate on the mud ring? (even a blank faceplate? but then how get patch cable through mud ring)  or do you put a 1x keystone faceplate and push the short cat5 patch cable trough the 1x keystone (but with no keystone in the faceplate, ofcouse).
thanks
