11-13-2023 03:20 AM
Hello
I have a question regarding the Dedicated Master. After i promoted my R750 to the Master i would like to upgrade the firmware to the latest version. Under the Administrator upgrade page i can check for updates but i cannot choose the Dedicated Master for it.
Does somebody has an idea?
BR
Bernhard
11-13-2023 09:30 AM
Hello @bernhard_rainer
Could you please confirm the current firmware version and build for the unleashed.
Also confirm if you have configured the smart-redundancy option in Dedicated master ?
Could you please check with the local upgrade option instead of online upgrade ?
When the user choose dedicate master mode , the user can upload AP firmware of various models.
In master mode , the user only can upload one AP model firmware.
11-13-2023 11:29 AM
Hello
Currently 200.14.6.1.199 is installed. Smar redundancy is not configured, caust the 750 will be the only one for now.
Local upgrade is greyed out.
BR
Bernhard
11-14-2023 08:59 AM
Could you please try to change the browser for the unleashed WebUI and check and if you are getting an option to upgrade via local upgrade.
