Config MAX power
rosa_mart_nez_m
It is possible to adjust the power of a specific AP to the maximum using cli?
1 REPLY 1
abilash_p_r
Contributor
Hi Rosa,
Command to adjust TX Power on the AP.
set txpower : set txpower
                 -- Set transmit power
Command to verify the TX Power
get txpower : get txpower
                 -- Get transmit power
Example:
rkscli: set txpower wlan0 2
OK
rkscli: get txpower wlan0
 wlan0 transmit power set to -2 dB from max power
OK
I hope this will help.
Abilash PR
