Compability Cisco Power Injectors and Ruckus AP ́s (r500, r600, H500)
golbert_salazar
I have a cliente that has 8 Cisco power injector air-pwrinj5= and needs to use this with some ruckus ap ́s for example r500, r600....so are they compatible????
I saw this pair (cisco power + ruckus ap) work!! but i ́m not sure about the advantages and disadvantages.....i will appreciate your opinion.
is there ruckus poe specification guide updated?????
Thanks guys for your help
Golbert
10 REPLIES 10
Excellent!! thanks for your help!! i have more clear the concept!!
golbert_salazar
Hi Sean,
Thanks for the answer!!, but i can ́t see the link about page 65...it shows an error: This XML file does not appear to have any style information associated with it.
Can you resend it to me again pls???
Thanks!
Cisco AIR-PWRINJ5 provides 802.11af (15.4W) power.
http://www.cisco.com/c/en/us/td/docs/wireless/power/quick/guide/pwrinj5.html
R600 AP power draw:
Idle: 2.3W
Typical: 5.3W
Peak: 12W
Click Specs from this R600 Indoor AP product page:  http://www.ruckuswireless.com/products/access-points/zoneflex-indoor/zoneflex-r600
Hey Mike,
The specs tab does not mention 802.3at but on the manuals it does.
