I am on a project in which I have to depoiloyer vSZ 5.1.0.0.496 and AP R510 for one our customers. Diagrams below. But I have a problem because the clients cannot get an IP address from the DHCP server.
Any suggestion will be welcome. Thank you in advance
If I configure vlans at the switch site, the machines obtain an IP address from the DHCP server. The problem is that our client had a ruckus ZD 1200 solution with the same configuration and the machines obtain an IP address without having to configure the different vlan on the switches.
For the DHCP request packets to reach the DHCP server, the branch routers have to have forwarders setup on the client VLAN, to forward the packet to the DHCP server.
