Cannot connect on second and other SSID Unleashed R310
rene_slager
Hello, I got 5 R310 and spreading 3 SSID's over al the AP's but one of them is showing the SSID's but when I try to connect the client doesn't get a ip adres of the AP the others are all working fine. Idea?Image_ images_messages_5f91c3f8135b77e2479023e0_52b200cee07c1c55429e180faf776569_RackMultipart20181227106976k7g-5f2215bb-da94-4608-beae-d3dbca2a02cb-955845248.png1545896995
Regards, Rene
11 REPLIES 11
DarrelRhodes
Valued Contributor
Hi Rene,
Do you have each of the WLANs mapped to a different VLAN?
Thanks,
Darrel.
rene_slager
Hi Darrel,
I have 3 diffrent VLAN's separated and assigned via the Unleashed portal to the SSID's. Ip ranges on the other AP's are good and separated by ip range.
Rene
DarrelRhodes
Valued Contributor
Hi Rene,
Thanks for the details.
It sounds like you have a VLAN mismatch or mapping issue.
Can you try swapping one of the working VLANs to the SSID/WLAN that you have the issue with to see if clients get an IP address, this will rule out issues with the WLAN config and confirm it is a VLAN issue.
Thanks,
Darrel.
rene_slager
Darrel,
That's strange because we don't have this issue on the other 4 Ruckus AP's so switching from VLAN don't make impact on the ssid...?
Rene
