Cannot access R310 via MacBook pro using 192.168.0.1
Cannot access R310 via MacBook pro using 192.168.0.1.
When I am trying to access R310 via the browser using 192.168.0.1 it is not reaching the access point.
I am connection R310 with POE switch for power and on another RJ45port I am connecting my macbook pro.  Still it does not work.
Can anyone help with this issue.
2 REPLIES 2
hayward_kong
Contributor III
Did you try resetting it yet?? After that if it still does not work, did you try ssh to it?
Esteemed Contributor II
Press the factory default button (indented pin by the Eth port) for 8 seconds, after the AP has fully booted.
Let it come back up again, and it should reply to pings to 192.168.0.1 and allow login SSH/HTTPS with
super/sp-admin uid/pw combination.
