Can't get APs to connect to ZD. Are the versions compatible?
I have bought the following kit:
ZD1200, running 10.2.1.0.75
ZF7372, running 9.10.2.0.63
I have factory reset them, put them on the same subnet, but they don't seem to want to talk. Is this just a versioning issue?
I have tried manually entering the IP of the ZD into the AP, but still no joy.
I have tried upgrading the firmware on the AP (under Maintenance > Upgrade), but I get an error ("Control file download problem").
I tried manually looking for a firmware upgrade, but can't see anything above V9.
I found a spreadsheet from Ruckus, that seemed to say that the ZF7372 could run under a ZD1200 on V10 (https://support.ruckuswireless.com/article_attachments/kA250000000TvhtCAC?attachment_index=0), but I can't work out how to make this work (or be sure that this is indeed my issue)
Any advice very much appreciated.
2 REPLIES 2
