Can I use SoftGRE tunnel for set of SSIDs while using local breakout for other SSIDs in the same AP
vSZ managed R500 AP will have 4 SSIDs. 3 SSIDs will use portal authentication and softGRE tunnel to Cisco iWAG as data path. 1 SSID will use traffic local breakout.
Is that possible to have this setup or should all SSIDs have either tunneled or local breakout traffic path?
1 REPLY 1
Esteemed Contributor II
Yes, you can have both tunneled and LBO SSIDs on an AP.
