Bridge Support - ZF7341
asad_faraz
We have a 4 ZF7341 AP.. I have to bridge my all ZF7341 (Access point) can someone please guide me . what configuration should be use . I cannot find any documentation to support this - in fact most seems to suggest that we have to use controllers for this purpose as 7300 Series does not support bridge option. Please help.
11 REPLIES 11
primoz_marinsek
Valued Contributor
IF you are talking about MESH then yes, you need to have a ZD for MESH to work. However think twice before doing this with 7341 APs. IT is not suggested to use this topology. Use dual-band APs for that.
asad_faraz
thx for your reply... so you mean to say that without controller we cant MESH 2 Access point. there is no option available in 7300 series .
Nope
can you please suggest which indoor access point can feasible for MESH . I want to use 3 Indoor access point without ether cabling or without controller expense. Please suggest which AP is suitable and working for this scenario .. so I can go for this. thx
