I'm struggling to get all this to work the way I need it to.
We have about 37 Ruckus R500s with an offsite host for the "Virtual SmartZone- High Scale" and the supplier isn't exactly very helpful...
I am only seeing 35 APs in the VSZ and they are now all showing as offline.
I want to add a new AP to the system to see what is going on.
Many of the devices were configured via CLI before being installed by the supplier. I need to be able to configure the devices in another way. I am looking at DHCP options to configure the devices and I need to do 3 things with our Windows Server 2016 DHCP
1) Configure the devices to switch to the wireless management VLAN
2) Configure the "set director addr " (this option appears to be missing from the CLI now)
3) Configure the "set provisioning-tag "
I'm struggling with configuring the DHCP and need some assistance.
I want to make use of the Vendor Classes to make my life easier and prevent conflicts with our coming VoIP system.
So I'm guessing I create a Vendor Class with the ASCII of "Ruckus CPE"
In Predefined Options, I need to add the new Option Types.
Each Option Type needs a name, data type, and code but I cannot find any consistent information on what these 3 entries should be.
Once the options have been created, I need to add configurations into them into the scope options. But again, these are not very clearly defined that I can make sense of.
Am I barking up the wrong tree or is this actually possible?
