11-22-2023 01:16 PM
I'm facing a problem and cant figure out how to solv.
When the clients are redirected to user_login_auth.jsp we receive a error: err_empty_response
Any help?
11-23-2023 07:12 PM - edited 11-23-2023 07:14 PM
Hi @agon1982
I believe this is a browser specific, could you please confirm if you are seeing this on all the browser?
Also please check on different clients.
I have seen some cases where an addon pluggin on the browser caused this, I also recommend you to upgrade the controller if it is running on older version.
11-24-2023 05:46 AM
This is, really, a problem with the chrome browser ( including Android mini browser to captive portal authentication).
I get the same error (no addons or extensions) when I try to authenticate to the Zonedirector web management console using google chrome (no problem with firefox or safari)
11-24-2023 05:50 AM
Zonedirector 3000 with 10.1.2.0 build 318
11-24-2023 05:05 PM
Hi @agon1982
Can you try upgrading the ZD 3000 to 10.2.1.0.236. That is the last version for ZD3000.
