Showing results forย
Search instead forย
Did you mean:ย
Amazon Echo Dot connection issue
I have an amazon Echo Dot that will not connect to our wifi.  We are running zd 10.3.0.0 build 398 with R510 APs.  I'm not trying to connect to a guest/captive portal network, just a normal SSID.  I have no issue connecting to this same SSID with a phone or laptop, but the echo dot after the password is entered it attempts to connect and then soon after says it cannot.
Any advice?
5 REPLIES 5
syamantakomer
Community Admin
Community Admin
Hi Colten,
Good to know that it started working.
Syamantak Omer
Syamantak Omer
RUCKUS Networks, CommScope!
Follow me on LinkedIn
