Creating a MESH with multiple AP's
russell_perry_6
I have recently bought in to Ruckus APs. Some config points below before the question
  • Initially, I was using a R310 200.7.10.202.94
  • I have now purchased 2x R610's
  • The internal IP range is 192.168.1.X
  • The ISP router is 192.168.0.X
  • In between the WAN and Lan I have a Luxul ABR-4500 to manage LAN IP's
Issue
When booting up the R610 whilst in config mode I could not get a connection. Therefore I plugged them in to the computer and went direct to the deafult IP 192.168.0.1 (that's was assigned to my ISP fibre router.
I altered the IP address and subnet of the first R610 to be in range of the R310 (Master - 192.168.1.161) and used 192.168.1.160 for the R610
When logging back in to the unleashed UI under 192.168.161. I can not add the new R610. Its just not appearing
Question
Should I have MESH enabled on te R310 or is there another way to add the R610 to the Unleashed AP's?
Thanks for your support.
Regards
Russell
8 REPLIES 8
phil_coverdale_
Internal Employee
Hi Russell,
The R310 AP does not support mesh.
Phil.
russell_perry_6
Quick response, which is always great to see! So would you suggest I get rid of the 310 and just use the R610s on their own?
phil_coverdale_
Internal Employee
Hi Russell,
Is it possible for you to connect the R310 to your network by Ethernet cable?
Phil.
russell_perry_6
Yep, thats possible
Labels
