Access Points - help me make a decision.
Need some help in decision making. This is for my house, 3k sqft, single level, ~40 wifi clients
I am split between
1. Two used R610 unleashed in mesh($300) from ebay - used, but enterprise class
2. Two TP Link EAP245 ($200)- cheapest, but still good.
3. Two Netgear business WAP610, wifi6 ($330)- expensive but wifi6
What I observed:
1. I feel the EAP and WAP610 on stand alone mode has tad more dbm than R610. Netgear in wifi6 connects at 1Gbps speed at times.
2. I really like the enterprise controls, parental controls etc available in R610 - not available in other two
3. Netgear packs wifi6, other two do not, this is my biggest gripe, should I stick to wifi6.
Question:
1. Seamless hand-off - will two R610's on a e-mesh support this? I do lots of video calls walking back and forth.
2. Family appreciates strong, stable and reliable wifi - I get into trouble if I cannot do that!
2. What are you suggestions?
All and any help appreciated!
6 REPLIES 6
Oof, I messed up.. in my back yard, I get 19dB not -19dBm. Right now I'm 4ft away from my APs which are mounted to my ceiling. The photo below is a metric from the R310 I use.Image_ images_messages_5f91c48f135b77e247aeb404_07ba629179144c6ceac7de2f11ee6c4b_RackMultipart2020092913022eht2-052d10cd-2346-4b5c-bf9b-48393ea64803-80811022.jpg1601402739
Unleashed does very good seamless handoffs but if you are going to be using meshing then I wouldn't push the SSID's out the 5ghz as well as the 2.4ghz.
