AP r510 remains provisioning
Hello, I have an AP r510 installed, the controller recognizes it but it remains provisioning it does not go from there.
10 REPLIES 10
sanjay_kumar
Hi Maykeling,
It looks like the config file is not delivered completely to the AP.
Probably due to MTU issue.
The ZD is sending the fragments which is in bigger MTU size than the MTU size set on the switch\network path.
Are there any switches, Firewall in between the ZD and AP?
If yes, please check the MTU set on these network devices.
Configure the MTU on the ZD lower than the MTU set on the network devices.
Example, if the Switch\Firewall has MTU set for 1300, then set the MTU on the ZD as 1200.
Set the MTU on the AP with the below CLI command
set mtu wan 1200.
sanjay_kumar
Hi Kumar,
this is the MTU value in the ZD
so it appears to me in AP in the ZD,  it is always provisioning.
Hi Maykeling,
Login to the AP CLI and reduce the MTU using the command "set mtu wan 1000"
See if that works.
I get an error when executing the commandImage_ images_messages_5f91c488135b77e247ad6e9b_1dd96740908be5d8a3776bde387bf50b_RackMultipart20200910217891xr7-b453d81f-f774-4821-b4cc-6676f02268ab-1218175730.PNG1599777269
