11-16-2021 09:56 AM
Can I use a 902-1180-US00 with a R710?
11-16-2021 10:33 AM
Hi Brian,
This part ID is not found.
Could you confirm what is the correct part number or device model you are referring to?
If you are asking about ZD1100 + R710, then answer is NO.
R710 is not supported on ZD1100 (EOL).
11-16-2021 11:17 AM
902-1180-US00 is a Ruckus POE injector.
11-16-2021 11:49 PM
Hi Brian,
Please find below guide which has list of Ruckus/CommScope POE and their compatible AP's. 902-1180-XX00 is compatible to R650, R750, R850
and T750.
https://www.commscope.com/globalassets/digizuite/62143-ruckus-accessory-guide.pdf
Best Regards
Vineet
11-18-2021 08:59 AM
thank you
