901-H320 -XX00 vs. -WW00
BobPitman
Hi, can anyone clarify the difference between these 2 products. Are both OK for use in the UK? Do either or both come with a wall bracket and POE injector?
5 REPLIES 5
BobPitman
Also - are these units still supported by Ruckus?
sanjay_kumar
Hi @BobPitman
901-H320 -XX00 is the Product information, where "XX" stands for the country information when ordering.
WW00 stands for "World Wide".
H320 is still supported on the current release of vSZ\SZ.
When ordering Indoor APs, you must specify the destination region by indicating -US, -WW, or -Z2 instead of XX. When ordering PoE injectors or power supplies, you must specify the destination region by indicating -US, -EU, -AU, -BR, -CN, -IN, -JP, -KR, -SA, -UK, or -UN instead of -XX.
Check out the Ordering information from the below datasheet.
https://webresources.ruckuswireless.com/datasheets/h320/ds-ruckus-h320.html
Thank you very much - very helpful.
BobPitman
Hi Sanjay
Do I need a bracket just to mount H320's on a wall?
