802.11r SQL Roaming
demetris_demetr
on a T300 AP where the max number of concurrent users connected is 500 (based on datasheet) i created 4 different SSIDs. I know that max concurrent users is related to the encryption and authentication methods. Let's say that the 3 SSIDs of them are open BUT the forth one has both WPA2 and 802.11r/802.11k enabled. The question is if the max concurrent users on the 3 open SSIDs will be affected by the 4th SSID.
Demetris
5 REPLIES 5
I assume, i will let you know my experience in the middle of the summer when toooo many guests will try to connect on the APs.
