05-29-2024 07:54 AM
I have 4 R600 access points running firmware 9.13.3.0.145. The zonedirector died so I converted them to standalone. What is the current best way to have these access points set up, would it be converting them to Unleashed or leaving them as is?
What is the latest firmware version I should install? Thanks!
05-29-2024 09:58 AM
hello @ap
The highest supported version for the R600 AP in unleashed code is 200.7.10.202.145.
Please refer the below article to convert ZD managed AP to unleashed
https://support.ruckuswireless.com/articles/000005720
05-29-2024 10:23 AM
Thank you, Ayush.
Is the best option to run the access points in unleashed 200.7.10.202.145? Or is there a better way I should configure them?
05-29-2024 11:55 AM
Thank you, Ayush.
Is unleashed the best way to reconfigure the access points rather than leaving them in standalone mode with the same SSIDs? Or is there a more recommended configuration?
