07-07-2021 03:49 PM
I am currently trying to setup a second Ruckus R710, however, it is not connecting with my master ap. With that, it is displaying a new configure.me ssid, this time asking for its serial number for the password, which I didn't have to do the first time. In addition to this, my computer is displaying that the configure.me has no internet connection, therefore, I cannot connect to its default ip address. I have tried doing a factory reset and have also tried applying a static ip to the configure.me. Nothing has worked so far.
07-08-2021 05:32 AM
Hi Ryan,
Configure.me will appear if AP is in factory default mode and cannot discover the controller (master AP).
If above doesn't work, please feel free to open a support case and support team will help you.
07-08-2021 01:36 PM
Thank you for your replay Omer,
I am fairly new to this so please excuse my confusion, but how would I check if I have a DHCP server? Is this through the switch? Also, if I do not have a DHCP server, what where and what I would enter for default subnet ip?
Thank you again,
07-08-2021 01:36 PM
*reply
07-08-2021 03:15 PM
Hi Ryan,
Could you confirm how your network devices are connected at present?
For example,
ISP connection >>> Modem/Router>>>> Switch >> APs
You have to first find out who is the DHCP server. It can be your ISP modem/router or switch.
Try to connect a devices on same subnet as your master AP and then run a IP scanner. It will give you more info like if your second AP got IP address from server or not, what is the gateway MAC address (refer the gateway IP of your laptop, when it is connected to wired network).
