09-20-2021 06:56 PM
I have 2 APs one in my office, and one in my bedroom. They are set up in an unleashed network and running R310_200.1.9.12.62. Once they attach to the network they get about 460 for network speed. When I walk to the bedroom - even after being in there 5 minutes they still are attached to the office AP but in the bedroom they only get 40mbit. This is why I got a second AP. They are wired ethernet to the same switch. I can see both in unleashed web and one IP roles to the other in the browser. Eventually they will roam to the closer AP.
Is there a way to encourage devices to hop to another AP more frequently?
09-22-2021 09:17 AM
Hi Boedillard,
Start with upgrading (make sure to create a configuration backup) the Unleashed latest supported version and then make below changes:
Please login: admin
Password:
Welcome to Ruckus Unleashed Network Command Line Interface
ruckus> en
ruckus# config
You have all rights in this mode.
ruckus(config)# wlan "AAA-Open-WAP3" >>>>>>>>> THIS IS THE WLAN/Wireless Network NAME
The WLAN service 'AAA-Open-WAP3' has been loaded. To save the WLAN service, type 'end' or 'exit'.
ruckus(config-wlan)# bss-minrate 12
The mgmt-tx-rate will be set to the same value as bss-minrate.
The command was executed successfully. To save the changes, type 'end' or 'exit'
ruckus(config-wlan)# end
The WLAN service 'AAA-Open-WAP3' has been updated and saved.
Your changes have been saved.
ruckus(config)# end
ruckus#
ruckus# show wlan name AAA-Open-WAP3 >>>>>>>> using this command you can review the WLAN settings. Look for "BSS minrate".
WLAN Service:
ID:
1:
NAME = AAA-Open-WAP3
Tx. Rate of Management Frame(2.4GHz) = 12.0Mbps
Tx. Rate of Management Frame(5GHz) = 12.0Mbps
Beacon Interval = 100ms
SSID = AAA-Open-WAP3
Description = AAA-Open-WAP3
Type = Standard Usage
Authentication = 802.1x-eap
Encryption = wpa3
Algorithm = aes-gcmp256
FT Roaming = Disabled
802.11k Neighbor report = Disabled
Web Authentication = Disabled
Authentication Server = Win2K12-235
Called-Station-Id type = wlan-bssid
Tunnel Mode = Disabled
Background Scanning = Enabled
Max. Clients = 100
Isolation per AP = Disabled
Isolation across AP = Disabled
Zero-IT Activation = Disabled
Priority = High
Load Balancing = Disabled
Band Balancing = Disabled
Dynamic PSK = Disabled
Rate Limiting Uplink = Disabled
PerSSID Rate Limiting Uplink = 0
Rate Limiting Downlink = Disabled
PerSSID Rate Limiting Downlink = 0
Auto-Proxy configuration:
Status = Disabled
Inactivity Timeout:
Status = Enabled
Timeout = 1 Minutes
VLAN-ID = 1000
Dynamic VLAN = Disabled
Closed System = Disabled
Https Redirection = Disabled
OFDM-Only State = Disabled
Multicast Filter State = Disabled
Directed Multicast= Enabled
802.11d State = Enabled
Force DHCP State = Disabled
Force DHCP Timeout = 10
DHCP Option82:
Status = Disabled
Option82 sub-Option1 = Disabled
Option82 sub-Option2 = Disabled
Option82 sub-Option150 = Disabled
Option82 sub-Option151 = Disabled
Ignore unauthorized client statistic = Disabled
STA Info Extraction State = Enabled
BSS Minrate = 12.0 Mbps >>>>> HERE
DTIM period = 1
Directed MC/BC Threshold = 1
Call Admission Control State = Disabled
PMK Cache Timeout= 720 minutes
PMK Cache for Reconnect= Enabled
NAS-ID Type= wlan-bssid
Roaming Acct-Interim-Update= Disabled
PAP Message Authenticator = Enabled
Send EAP-Failure = Disabled
L2/MAC = No ACLS
L3/L4/IP Address = No ACLS
L3/L4/IPv6 Address = No ACLS
Precedence = Default
Proxy ARP = Disabled
Device Policy = No ACLS
Vlan Pool = No Pools
Role based Access Control Policy = Disabled
SmartRoam = Disabled Roam-factor = 1
White List = No ACLS
URL Filtering = Disabled
Application Recognition & Control = Disabled
Apply ARC Policy = NO POLICY
WIFICalling Enabled= Disabled
WIFICalling Profile= 0
Client Flow Data Logging = Disabled
Wlan Bind = all
Client Connection Data = Disabled
Transient Client Management = Disabled
80211w-pmf = Required
