Nexus device not conneting to R 700 Wireless which is connected to vSCG controller
7 REPLIES 7
hi,
Please confirm the following
software version on Vscg?
does nexus connect ok on open or no security ssid?
try cloning your ssid and see if nexus connects on TKIP WLAN or AES WLAN?
pls give it a shot..
Best of luck..
and another device connects ok ?
I have changed Algoritham to AES, all Nexus are connected now except one nexus table has ! mark on network symbol and not browsing internet
mark on network symbol ?
You mean it cannot connect at all to the SSID ?
You can check in the webgui under administration / diagnostics / application logs, the system / events log. search on the mac of the phone.
