Upgrading from Old ZoneDirector 1006 to ZoneDirector 1200
I am upgrading my existing ZoneDirector 1006 with firmware 9.3.4 to a newly purchased ZoneDirector 1200 with the default firmware - which should be 9.8.something.
I have about 25 APs, VLAN config, SSID, all the bells and whistles including all the naming convention, location, very-very detailed settings..
I tried to backup the settings on the ZD1006, then proceed to ZD1200, and tried to restore...
Oops, bad news - the settings is not compatible and I am stuck.
I really don't wish to re-configure all the settings from scratch.. any-way I can migrate the configuration without having to re-do all the AP and WLAN information?
18 REPLIES 18
"supported" AP can upgrade/downgrade from any to any BUT you need to look for AP's which are supported. ZD1000 and ZD1200 are generation apart...
yep, i have confirmed that my ZF7343 are supported in ZD1200 9.9 firmware.
I am having problem right now with my ZD1100 upgrade though. I am stuck in the upgrade progress from 9.5 to 9.7... it just get stuck with blinking red status light and it refuses to upgrade...
Esteemed Contributor II
Hi Joke, Did you get as far as 9.5.3.0.44, before trying to go to 9.7?
https://support.ruckuswireless.com/software/410-zd1100-9-5-3-0-44-mr-software-release
If you simply do a ZD reboot, does it come back up (green Status LED) shortly, so you can try again?
The ZD 9.7.2.0.9 Release Notes do say you can upgrade from 9.5.1.0.50 however.
https://ruckus-support.s3.amazonaws.com/private/documents/488/9.7.2.0.9_-_ZoneFlex_9.7.2_Release_Not...
A ZD1100 can seem to take a long time to upload the image (flashing red LED), so sometimes give it up to 30 min.
I manage to get the 9.7.2.0.9 from my previously downloaded link. but It's not available on the website which I think your team might need to put in for ZD1100.
I manage to get to 9.5, and the problem only happened when trying to upgrade from 9.5 to 9.7.
The trick i used was to power-cycle first, then once I get into ZD after it was upgraded from 9.3 to 9.5, I went to the admin > maintenance > reboot > power off button. Once it's powered off, then I power-cycled the device again, and I was then able to upgrade to 9.7, and then later on to 9.8, and then to 9.9...
It was a really long and tedious process... albeit brainless..
