USING MIB TO MONITOR AP STATE
I need to see the state (Up /down) of my Ap's on EON (Eyes of network). I use the  Virtual SmartZone - Essentials (vSCG-E01).
Can you tell me how to do? with the command snmwalk ? OID?
Than you in advance
2 REPLIES 2
Esteemed Contributor II
Download the SNMP MIB file for your version of SmartZone and load it on your system.
https://support.ruckuswireless.com/products/83-virtual-smartzone-vsz#firmwares
I installed MIB and downloaded the documentation but I don't know which one to choose. Which mib do I need to know which AP is up or down?
Regards
