Ruckus zoneflex 7341
sanjay_singh_59
Hi
I have a zoneflex 7341,but at some place the signal is very low.So it that possible that we can have repeater of any make like dlink for signal strength.
3 REPLIES 3
primoz_marinsek
Valued Contributor
Yes, you can, but you probably shouldn't. A much better option would be to use MESH or run some more cable to the location. It costs a bit more, but it is much much better alternative than a repeater.
Can't you move the 7341 a bit to cover that area? Is it too far?
sanjay_singh_59
No, i can't . Is there any way to use repeater in ruckus
primoz_marinsek
Valued Contributor
You can use MESH if you have a ZD on location. MESH doesn't work without the ZD.
However there was a MediaFlex 7211, but it's EOL. Maybe you could get your hands on one of them. At least its better than a D-Link.
