Ruckus Cloud Wifi service hours
johan_castro_a
Hi everybody.
I'm migrating from ZD to Ruckus Cloud, is there an equivalent option to WLAN Service Schedule? I use it on the ZD but I can't find it on the cloud version.
Thanks.
1 ACCEPTED SOLUTION
johan_castro_a
I had to open a support case. Yes, there is an equivalent option, it's a little bit hidden if you're used to Zone Director but it is there.
1 REPLY 1
johan_castro_a
