R500 WiFi speed (2.4 and 5) seems limited to 100mbps despite FIOS Gigabit
christopher_hay
Have read many posts and am convinced I have some type of configuration issue.  All of my new devices (e.g., iPhone XS, Surface Pro 6) seem to top out at 100/100mbps.  I don't use mesh, have 3 R500s and a ZD 1200 connected to Verizon FIOS Gigabit internet which delivers 800+mbps to my hardwired devices/PCs.  Have setup separate 2.4 and 5 networks and they all seem to max out at 100mbps.  Just seems too coincidental.  It's a private home with no interference.  Thanks
6 REPLIES 6
hyosang_choi
Valued Contributor
Check wired-speed.
It may be connected 100/full.
christopher_hay
Hi.  Thank you for all the help.  Diego and others cracked it for me.  Apparently my AV guy had a small 10/100 ethernet switch between my fast FIOS wires and the ZD1200 and some other AV equipment.  I replaced it with a simple Gigabit ethernet switch and bingo!  All is good.  Thanks!
