Connect AP ( R510) to Virtual SmartZone - Essentials 3.6 using wireless only ( without cables conected to the network)
Connect APs ( R510)  to Virtual SmartZone - Essentials  3.6 using wireless only ( without cables connected to the network) - I`m planning to use Mesh but I don`t wanna make  pre setups using network cables.  note: I`m not using unleash
3 REPLIES 3
DarrelRhodes
Valued Contributor
We have introduced 'Zero Touch Mesh' in the SmartZone and Solo AP software platforms.
The following are the Zero touch mesh limitations.
  • Zero-touch mesh only supports 5Ghz
  • Zero-touch mesh only supports Solo AP 110+ and SZ AP 5.0+
  • When Solo AP upgrades from previous release (for example 104 or 106) to 110, AP needs a set factory option to activate zero-touch mesh
  • When Solo AP has the updated configuration (for example, WLAN configuration update), the AP needs a set factory option to activate zero- touch mesh
I hope that helps.
Darrel.
Hi Darrel,
So it means that do I have that to update my smartzone essentials version if I wanna have this feature?
Beginner
martin_martin
Valued Contributor
Hi Beginner,
Correct controller running v5.x, and your AP should have the new version also which has the zero-touch mesh code, I think it is 110.x.x.x
Regards
Martin
