Limit dB signal for access
We have a ZD1106 controller and some r600 zoneflex. I would like to know if it is possible to configure a limit on the signal power in the access of the users?
For example. If a user is too far from the AP with a -70 dBm signal he will not be able to connect or the AP will disconnect the user.
It is possible?
3 REPLIES 3
Esteemed Contributor II
The BSS min-rate can tighten the circle of coverage required for user connections,
often used in conjuction with OFDM-only (no 802.11b clients allowed).
https://support.ruckuswireless.com/answers/000001657
Michael,
Thanks for the answer!!!
You're most welcome!
