Hotspot Web page for Virtual SmartZone
andr_vila_nova
Hi Team,
Can anyone confirm if I can use the same documentation down below for Virtual SmartZone - (vSZ) or Is there another one?
Enabling WISPr (Hotspot Services) in the ZoneDirector:
https://webresources.ruckuswireless.com/pdf/appnotes/appnote-wispr.pdf
Thanks a lot.
4 REPLIES 4
eizens_putnins
Valued Contributor II
Hi, there are differences for SmartZone. But there is much better and more detailed information on the subject available specifically for Smartzone for each latest version.
https://support.ruckuswireless.com/documents/3646-smartzone-6-0-0-ga-hotspot-2-0-reference-guide-sz1...
@eizens_putnins I appreciate it, I know there's a different setup for the models, but my main question is if I can use the same authentication page, this one in HTML, in the SmartZone, 'cause there's not that authentication page in this documentation.
syamantakomer
Community Admin
Community Admin
Just to add on, vSZ-E/SZ100 and vSZ-H/SZ300 has different guides fir 5.2.x and older versions, so make sure you pick the right one as per your controller version.
Also provided link is for 6.0 version, so If you are on different version, go to below link and select the correct version first and accordingly refer the correct WISPr referance guide.
https://support.ruckuswireless.com/products/83-virtual-smartzone-vsz?open=documentation
Syamantak Omer
RUCKUS Networks, CommScope!
Follow me on LinkedIn
@syamantak_omer I appreciate it, I know there's a different setup for the models, but my main question is if I can use the same authentication page, this one in HTML.
