I am trying to deploy a Guest Network using ZoneDirector 9.12.2.0 build 204 and a couple T300 Access Points.
I created a WLAN called FYL and everything works fine on Standard Usage. But I want to set up a captive portal page with Guest Access. It seemed to work once on my iPhone, but now it never gives me a portal page and doesn't give me any internet connectivity. If I switch it back to Standard Usage.. it works again.
I do notice that under Monitor/Wireless Clients, it shows my phone (with a valid IP, the same in fact, as when I am connected with Standard Usage) connected to the correct WLAN, but it says Status of Unauthorized and Auth Method as Web. I am using Open authentication and no encryption at the moment.
I have been through these configs over & over and I can't find my problem. I have read many web setups and mine isn't any different than those recommended. Any tips or directions would be greatly appreciated.
-Steve
