Filter SSID to be broadcast by an AP using ZD3000.
erwin_james_mic
I have multiple ZF APS manage by my ZD3000. I also have multilple wlan in my configuration. Is it possible to make a specific AP broadcast specific WLAN?If yes, how can I do it?
5 REPLIES 5
primoz_marinsek
Valued Contributor
You have the option of configuring WLAN groups and AP groups.
With WLAN groups you make a group of WLAN that you then deploy on either an AP group or on individual APs.
erwin_james_mic
Iv'e already created a WLAN group but how can I deploy it on an AP??
primoz_marinsek
Valued Contributor
You go to Configure :: APs and either make an AP group and put APs and your WLAN group into it or Edit the individual AP and enable that WLAN group on it.
erwin_james_mic
Thanks..
Type a product name
