Hi
We currently have a Wireless Network setup consisting of Ruckus ZoneDirector 3000 (using latest 9.9 firmware) and ZoneFlex Model 7982, 7762 and 7363.
The Core Switch is a Cisco 4507 R+E with a collapsed core design. Access Switches are 2960S connecting to the Core using Fibre Optic Cables configured as Trunkports. The AP's are connected to the 2960S Access Switches.
The Core Switch is doing the Routing between VLANS and the port configuration between Core - Access Switches - Access Points are identical which are listed below
switchport trunk encapsulation dot1q
switchport trunk native vlan X
switchport trunk allowed vlan X,Y,Z
switchport mode trunk
We are seeing excessive MAC FLAP notifications on the switches "show logging" command which we are suspecting is the cause why some of the AP's are going Up and Down. The Network is also sluggish when these MAC FLAPS are occurring. No other syslog messages can be seen on the switch, only MACFLAP and ofcorse if the interface becomes down or up.
A sample of the MAC FLAP log on the switches is shows below:
Mar 2 09:24:42.773: %SW_MATM-4-MACFLAP_NOTIF: Host 6420.0cbb.672b in vlan Y is flapping between port Gi1/0/3 and port Po3
Mar 2 09:24:43.156: %SW_MATM-4-MACFLAP_NOTIF: Host c462.ea85.c4f7 in vlan Y is flapping between port Gi1/0/3 and port Po3
Mar 2 09:24:43.193: %SW_MATM-4-MACFLAP_NOTIF: Host a088.b4e6.5f80 in vlan Y is flapping between port Gi1/0/3 and port Po3
Mar 2 09:24:45.143: %SW_MATM-4-MACFLAP_NOTIF: Host 6caa.b314.8590 in vlan Xis flapping between port Gi1/0/3 and port Po3
Mar 2 09:24:45.783: %SW_MATM-4-MACFLAP_NOTIF: Host 6caa.b315.4370 in vlan X is flapping between port Gi1/0/10 and port Po3
Mar 2 09:29:17.224: %SW_MATM-4-MACFLAP_NOTIF: Host 6caa.b314.a1e0 in vlan X is flapping between port Po3 and port Gi1/0/11
Mar 2 09:29:17.224: %SW_MATM-4-MACFLAP_NOTIF: Host 6073.5c80.8d3f in vlan Y is flapping between port Gi1/0/10 and port Gi1/0/11
On this particular Area having these excessive MAC FLAPS there are (2) access switches that are 24 Ports with 13 ports used to connect to ZoneFlex AP's.
Is there some configuration adjustments we can do on the ZoneDirector to help resolve this issue? Or any best practice configuration we can use on the Cisco Switches using Ruckus Wireless Access Points?
We also have a similar setup with our other clients and we are experiencing the same problem which we are still trying to resolve.
Please advise.
TZ
