I currently have 2 R710s (one upstairs and one downstairs) in an Unleashed setup. Everything works great, except I have ~3 devices that are Ethernet only, and they're nowhere near an Ethernet drop :(.
I DO, however, have an old R700 collecting dust. I assume I can set it up in standalone mode (since it won't work with Unleashed) and set it up like
https://support.ruckuswireless.com/articles/000003332 and it should mostly work, as long as I disable directedDHCP? I only need to bridge over 5Ghz, not 2.4Ghz, and I was planning on setting up separate SSID (and probably VLAN) just for the bridging.
If I, however, instead get a 3rd R710 and added it to the Unleashed network, can I just use the mesh stuff to bridge it that way without disabling directedDHCP? I've done a ton of wireless, but never bridging. Everything says to use WDS, even though it's flakey. The above URL though says that Ruckus doesn't really "do" WDS, which is why I'm asking.
Thanks for the help and support for the stupid questions!
