Connecting to island SSID
Is there is anyway to get connected to AP via island SSID which is broadcasted by AP with Default configuration?I heard that we can actually get into it.
2 REPLIES 2
Esteemed Contributor II
Yes, please search for "island" under Knowledge on the Support portal.
There are KBAs for ZD managed APs with Mesh enabled, or Standalone/Solo AP mode broadcasting
the 'island' SSIDs and how to get into them.
vamsi_krishna_h
you can get to it by using a password "ruckus-" default is "ruckus-sp-admin"
