Hi Michael.
Thanks. Do you have a step-by-step guide on how to do it?
"802.1x requires a RADIUS server in front of your AD/LDAP backend.
You can use AD/LDAP directly to authenticate WebAuth, Guest Access, or users going to
http:///activate to setup DPSK."
Here is what I want on DPSK:
1. When the user tries to access the internet, the user needs to enter the username and password credentials. ( Instead of using the the local authentication server of ZD, I will be using an external LDAP server ).
2. Once the username and password are entered, the user will be prompted to download the prove.exe file.
Thanks.
