connect Ruckus R320 with Cisco switch
chidung_nguyen
I have Ruckus R320 and I connect it with Cisco switch, but it not connect, so in Cisco switch I need add management vlan ?
my config in Cisco:
"switchport trunk allowed vlan 2,10,15,30,205
 switchport trunk native vlan 999
 switchport mode trunk
 switchport nonegotiate"
management vlan is 205.
Thanks a lot!
9 REPLIES 9
hi Arun N!
Thanks for help, I aready follow your guide, however I still can not connect with AP ruckus R320, AP running Unleshed ( this AP is not master).
Hi Nguyen,
Can you please share the output of the following command.
get ipaddr wan
Arun N
Image_ images_messages_5f91c47e135b77e247ab9a19_cec149c2db6b876ae62212c41113b366_RackMultipart20200521439481ar1-19bbf253-33bf-4a37-9bc9-3abe20846765-1485157621.PNG1590051474
my command inmage. I see it use vlan1, but I want set vlan 205 for this AP.
Hi Nguyen,
The Vlan is still 1, it is not changed to 205. Only when you change it to 205, the AP will get an Ip address from 205 and connect to the network. As per your setting on Cisco switch.
I would recommend you to please open a case with our Support team, so that we can help you out on a remote session.
You can use the following link to open a case
Arun N
hi Arun N!
Thanks so much, your information very helpful
