11-06-2020 12:00 PM
I can't seem to locate the firmware that increases this to 50 or 70.
As well, we have an R310 that says it will be left as unmanaged if we update to what's available from the Master.
11-06-2020 12:11 PM
Hi John,
It is 200.7 version which support up-to 50 APs. It is also the last version which support R310. Beyond that, ac wave-1 APs are no longer supported.
You can upgrade to 200.7 version.
11-06-2020 12:55 PM
Starting from 200.8 we have increased the AP support to 128 in a single network (and 2,048 concurrent clients support). As it was baselined using the least common denominator on hardware, so we had decided to remove the support of the Wi-Fi 5 wave 1 APs so we can allow *any* APs to act as the master role. As you may know we have built-in the controller function inside the AP itself so it was a tough decision to say goodbye of our popular R310 starting 200.8 which was on an earlier version of the hardware spec.
11-06-2020 12:11 PM
Hi John,
11-06-2020 12:55 PM
11-06-2020 01:04 PM
That answers my questions - thank you both.
11-06-2020 01:09 PM
Glad to help you John!
