Showing results forย
Search instead forย
Did you mean:ย
Setting ethernet port mode to bridge in Unleashed (R500)
The R500 has two ethernet ports. It seems however there isn't the level of detail or configuration i'd expect with the physical ports compared to the flexibility of other options in Unleashed.
I checked the command line but the only reference is in the ethernet port status:
ruckus# show ethinfo
System Ethernet Overview:
  Port  0:
    Interface= eth0
    MAC Address= d4:00:00:00:00:00
   Physical Link= up
    Speed= 1000Mbps
  Port  1:
    Interface= eth1
    MAC Address= d4:00:00:00:00:01
    Physical Link= down
    Speed= 1000Mbps
What i want to do is be able to bridge the second port in, so another device can connect to the network. So fairly simple. Note i have not connected the device yet. How do i set this?
However as an aside, i would have thought i could also configure the vlan options of each port, whether it is trunk/access mode, etc. Am i missing something?
Thanks.
6 REPLIES 6
can you have a switch connected to that port? will DHCP pass through?
Thanks.
Ian.
syamantakomer
Community Admin
Community Admin
Hi All,
Only limited AP models are supported for Ethernet port profile. Refer the below video from our official YouTube channel.
RUCKUS Unleashed Ethernet Port VLAN Support Configuration using Browser UI
Syamantak Omer
RUCKUS Networks, CommScope!
Follow me on LinkedIn
