R310 Certificate Problem
kieran
Hi
I recently installed a new certificate on my R310, and since installing the certificate I can no longer access the admin UI on the device. I’ve tried factory resetting the AP as it hasn’t cleared it. Does anyone know of a way of restoring the self signed certificate?
Thanks!
1 ACCEPTED SOLUTION
kieran
Hi
So to fix it incase anyone else has the problem.
1) Reflash the standalone AP firmware via ssh
2) Factory reset the unit to get the default login
3) Upload the unleashed firmware via the web ui
4) Hey Presto! The default certificate is restored
Thank you for all your help.
13 REPLIES 13
sanjay_kumar
RUCKUS Team Member
Try below steps:
set https disable
set http enable
And then access the AP from the IP address http://ipaddress
kieran
Hi
Thanks, but still trys to redirect to the https version of the site 😞
BobaEnjoyer
I'm still new to the CLI, but I just found:
no web-portal-force-https-redirection
                       Disables web portal force HTTPS redirection.
It's under "config" in the beginning, right after you "enable"
So:
1.  SSH in.  Log in as your admin account.
2.  enable
3.  config
4.  no web-portal-force-https-redirection
5.  exit
(exit saves changes in that menu.  abort or quit will cancel changes and go back to the previous menu.)
Maybe this will work.
kieran
Sends me back to https site still 😞
It shocks me that there is no way to reset the SSL certs via CLI as most other equipment I've used allows you to do it
sanjay_kumar
RUCKUS Team Member
Can you try converting the AP to Standalone version from CLI upgrade and then see if it helps?
https://support.ruckuswireless.com/articles/000001551
