07-30-2025 07:58 PM
Hi Ruckus Team,
Is there a way or solution to view historical data from Unleashed Access Point such as the number of clients on a particular day, then also the rssi value and what ssid the client is connected to? And can visualized data to Grafana?
Thank you.
08-05-2025 07:14 PM
@Mayank wrote:A. Unleashed API (Recommended for Custom Grafana Integration)
Unleashed provides a REST API that you can query for client and AP statistics.Enable Unleashed API (on the Master AP).
Access the Unleashed Web UI.
Go to Administration > Management > API Access.
Create an API user or use existing admin credentials.
Did you use ChatGPT to create this answer?
"Administration > Management > API Access" doesn't exist in any Unleashed version you've released to the public.
And "Create an API user" isn't available on any Unleashed version either. Users have either Admin, Operator or Monitoring roles.
08-06-2025 11:01 PM
Hi ms264556,
Thank you for the update,
We need to check this internally hence, Please log a ticket with the below link so that we will help you further.
