Continue wired network from mesh node
Is it possible to continue a wired network from a R500 mesh node?
I am running a unleased r500 mesh network with the main node connected to a router with internet. I would like to add a switch to a mesh node on the other side of our building to add some computers (without wifi) on that end.
10 REPLIES 10
Esteemed Contributor II
I'm not sure static IP clients beyond Mesh AP will work, as Ruckus would have no way to know those client MACs exist.
We don't have the commands to say this mac with this IP is on this interface, unless it's on your AP switch port side...?
Please share your test results.
This is the situation I would like to create:
Image_ images_messages_5f91c43b135b77e2479d3296_f9b768755b256a1c20948e27a2ca1f0a_RackMultipart20180313766433owf-792022c5-4629-4b62-a44b-2f5e78d9576c-2071203871.PNG1520931635
yes its doable as suggested earlier.. thx
Found this in Ruckus documentation. It might be easier than I thought.
Image_ images_messages_5f91c43b135b77e2479d3e2a_ed7f85382acd1e744987cdf583def2b3_RackMultipart2018031433054ra42-c36777b7-b8d3-448f-b993-ca51563ad451-202740364.PNG1521009888
yes, its pretty much the same you made...
