Alarm settings vs Events - Unleashed (R500)
I'm new to Ruckus and Unleashed. I've configured two R500 in Unleashed mode.
Software is updated to the newest one - 200.1.9.12.62.
I was watching the instructional videos and found out that in Admin & Services - Administer - Diagnostics - tab Debug info you check the options which you want to appear in the Events tab, like RF management, Client Association, etc.
On the other hand in Alarm Settings you see the most important events.
I see none of those events set in Debug info tab in the Events tab.
Basically Alarm Settings tab and Events tab have more or less the same info.
Alarm tab:
2016/06/15  09:35:07 Rogue AP DetectedHighA new Rogue[xxxxxx] with SSID[xxxx] is detectedClear
2016/06/15  09:35:07Rogue AP DetectedHighA new Rogue[xxxxx] with SSID[xxxxxx] is detectedClear
2016/06/15  09:35:07Rogue AP DetectedHighA new Rogue[xxxxxxx] with SSID[xxxxxx] is detectedClear
2016/06/15  09:35:07Rogue AP DetectedHighA new Rogue[xxxxxxxx] with SSID[BO_AP_5] is detectedClear
2016/06/15  09:32:24Rogue DHCP Server DetectedHighRogue DHCP server detected on [xxxxxxxx]Clear
2016/06/15  09:32:07[Smart Redundancy] ConnectedHigh[Smart Redundancy] Peer Unleashed[xxxxxxxx] connected, system is in active state.Clear
2016/06/15  09:32:02[Smart Redundancy] ConnectedHigh[Smart Redundancy] Peer Unleashed[xxxxxxxx] connected, system is in standby state.Clear
2016/06/15  09:31:24[Smart Redundancy] State ChangedHigh[Smart Redundancy] Peer Unleashed[xxxxxxxxx] not found, system changed to active state.
Events tab:
2016/06/15  09:35:0 High A new Rogue[xxxxxxx] with SSID[xxxxxxxx] is detected
2016/06/15  09:35:07High A new Rogue[xxxxxxxx] with SSID[xxxxxxx] is detected
2016/06/15  09:35:07High A new Rogue[xxxxxxxx] with SSID[xxxxxxxx] is detected
2016/06/15  09:35:07High A new Rogue[xxxxxxx] with SSID[xxxxxxxx] is detected
2016/06/15  09:32:24High Rogue DHCP server detected on [xxxxxxxx]
2016/06/15  09:32:12High [Smart Redundancy] Sync configuration to peer Unleashed[xxxxxxx]
2016/06/15  09:32:07High [Smart Redundancy] System state changed to [Active] due to [the role is master]
2016/06/15  09:32:07High [Smart Redundancy] Peer Unleashed[xxxxxxxx] connected, system is in active state.
2016/06/15  09:32:02High [Smart Redundancy] Peer Unleashed[xxxxxxxxx] connected, system is in standby state.
2016/06/15  09:31:44High Rogue DHCP server detected on [xxxxxxxx]
2016/06/15  09:31:24High [Smart Redundancy] Peer Unleashed[xxxxxxxxxx] not found, system changed to active state.
Is this a wrong information in instructional videos or am I doing something wrong?
0 REPLIES 0
